1992 M998 HMMWV Hub Question
shor2832
Middletown, RI
I was just looking everything over today and saw oil leaking on the tire of the front right hub. I immediately thought the worst - blown seal or something but it seams this rubber line isn't connected to the hub. Is it a breather? The oil was definitely coming from this area. Any thoughts?
NDT
7,376
Camp Wood/LC, TX
It is a breather, look for a small poly line that should be attached there. I would reconnect the line, refill the hub, clean the oil up, and go for a ride. Most likely the oil is coming from the seal.
shor2832
Middletown, RI
Yes you can see the breather line in the pic. The wierd thing is it is too short by about four inches to connect- the clamp is still on the end and everything. It is carefully routed and held in place with about four or five hangers.
