1998 m1078 LMTV A0 just bought from government planet and it looks like they drained all the fluids heeeeeeeeelp.
Seapup
Washington
So before I fired the next toy up I was checking all the fluids and it looks like everything except for the steering is empty:/
Glad I didn’t drive that down a steep driveway before I checked everything.
So Transmission oil
Fuel tank “oooouuuuuch$”
steering fluid
both front and rear diffs are tanked up now
but there’s a couple more things on the door that were written in sharpie that has long disappeared and I can only make out a partial shadow of it.
Something about mounts
Something about a filter removed
Looks like I can’t seem to think of anything else to check except for the hubs anybody else have any ideas?
What filter would they remove?
Thoughts , comments, any good jokes going around???
Thanks in advance
coachgeo
3,365
North of Cincy OH
Most this put together by @simp5782
Engine crankcase 25 quarts 15W-40
Transmission @ oil change: 31.8 quarts (15w40 OR Mobile ATF D/MNAPA ValvolineDextron III 5galNAPA - VAL 349
Transmission @ overhaul: 39 quarts
Steering: 5 quarts hydro fluid or steering fluid Aw32 or extreme situation Aw46
Hydraulic reservoir winch/crane truck: 27 gal.- BEST OE/HDO-10, then SAE 10w oil, lastly Aw32
Hydraulic reservoir cab/tire lift : BEST Royco 756- then Aw32, lastly standard 10wt Hydraulic oil
Front diff 4x4 & 6x6: 9.5 quarts SAE 75w90 GL4
Rear diff 4x4: 18.05 quarts SAE 75w90
Rear diff 6x6: 9.5 quarts SAE 75w90
Intermediate axle 6x6 13.7 qts SAE 75w90
Front planetary hubs 4x4 & 6x6: 11-13 OZ SAE 75w90 GL4
Cooling system total: 43.8 quarts antifreeze (HD diesel truck that meets A-A-52624)
Cooling system w/ arctic kit: 58.3 quarts
FILTERS
General CAT filter pdfCAT
Air FilterNAPAFIL 500047TruckPro/BaldwinNOT AVAILOREILLY/WIXWA10047
Fuel Filter 3116 / 3126Various7E 9763
Fuel Filter C7Various33626
Fuel/Water SeperatorNAPAFIL 3755TruckPro/BaldwinBF9912-OOREILLY/WIX33755
Oil FilterNAPAFIL 1791TruckPro/BaldwinB76OREILLY/WIX5179
Transmission Filter KIT (MD3070(SP)NAPAFIL 7741XETruckPro/BaldwinPT9416-MPG KITOREILLY/WIX57741XE
Filter Hydraulic Winch/Crane etc trucks onlyParker932618QBaldwinH9052Wix (Napa version)57902 (7902)DonaldsonP165015
Power SteeringWix*57131FramCH803APL*that number should lead one to many cross references to favorite manufacture
Seapup
Washington
FILTERS
Got it.
Perfect
And thank you.
The TM’s are less than intuitive but if I bang my head against them hard enough the information gets in.
got it sorted out….
Thanks again guys!
