2 high not working on deuce
AceHigh
31
Lake City FL
I read the title and thought you were too high to work on the truck. My bad.
Is it slipping or is the engine being pulled down to a stall? Good luck on it.
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
Time to start looking for a trans. Second gear is the deuce transmission's weak spot. It probably took out the main shaft.
1,187
I think he is saying it does not move in high range(transfer-case).
Perhaps a better description of his problem would help.
gimpyrobb
27,787
773
Cincy Ohio
Ah, that makes sense. get under and check the transfercase linkage for the "detent" settings. It might need adjustment.
