200 mile drive with leaking hub boots
1lineman1
cin. ohio
I've done my homework on replacing boots on these units with a Non zipper type. My question is i'm looking to maybe purchase a truck 200+ away. 2 of them are leaking. Do i need to worry about the bearings running dry? I'm a slow driver anyway so speed won't be a factor. Just didn't know if i needed to prepare with lots of duct tape and garbage bags and tubes of grease. Or does most of the grease stay in and the real concern is H2O and contaminants getting in ? I'm not even gonna attempt to use the zipper style from what i've read.
simp5782
Feo, Fuerte y Formal
9,267
Mason, TN
Zipper boots keep the grease in the steering knuckle area. They do not have anything to do with the hub bearings as they have their own inner seal on the spindle. I have had busted zipper boots for nearly 3years and 200,000+ miles without issue. Just grease them up when you need to. Only be concerned if you are offroading and water intrusion into the steering knuckle that way.
1lineman1
cin. ohio
yeah that would make sense seeing that there behind the hub seal ... haha not sure what i was thinking. In any case that doesn't concern me as much then. thanks !
snowtrac nome
137
western alaska
the seal is the inner axle seal its leaking differential fluid. the wheel bearings in the hub are greased the real reason for the boot is to keep water and debries from getting into the bearings through the back side of the spindle, unless you have the old rezeppa type joint than you need a surplus of grease. if you have the spicer cross type universal joint excess grease just costs you dollars.
1lineman1
cin. ohio
I mean shurly there's a seal behind the inner spindle beari g though right ? I definitely get that there's a differential seal.
1lineman1
cin. ohio
Just to clarify what I'm trying to avoid. Having 2 known leaking boots that when under highway speed start throwing grease everywhere from the steering knuckle. To me it sounds like that won't be the case.
