mow***com
- 243
- 33
- Salt Lake, Utah
Time for another update... Well, life is still funny sometimes.
Not too long ago, I noticed the truck getting harder to start. Mind you, I plug my block heater in for a couple hours each morning.
So, I was a bit puzzled as to why it wasn't starting. Until, I figured out that my Zerostart 1000W block heater had shit the bed.
Being me and enjoying doing jobs multiple times, I headed over to the local auto parts store for some type of immediate replacement.
Sadly, they only had the Katz and I just had a feeling it was gonna fail. Two days later, it failed....
So, I ordered yet another Zerostart 1000W block heater and will give this another shot. It just isn't fun draining the coolant, just to do it all over again.
I've had enough older diesels to know that my 6.5 doesn't like sub freezing weather.
Even an hour on the block heater and it starts right up.
Anyway, that is the fun that I've been dealing with at the moment.
That and I've started to test my wiring for my 24/12-70 converter.
I ultimately decided to just run my signal wire to the ignition switch. Since, I already have a keyed set up, I've got threaded studs/lugs on the back of the switch.
With no load, it reads 13.5 volts. With the stereo hooked up, it reads 13.3 volts. I can adjust that as I need.
I still don't have speakers for the stereo. But, I'll probably just construct a temporary speaker box until I can think about it some more.
That's about it for now. Hopefully, it will be driving again in the next few days. Until then, maybe I can get the wiring dressed up and possibly get amplifier/subwoofer wired up. Anything is possible.
