- 7,744
- 155
- 63
- Columbus Georgia
Looking for interior repair parts OR the center section of the retractable light reel .... needed for Doc's M170 Ambulance. See me at the Rally if you have anything. Thanks
Great buy!!!I'll take everything on the pallet for $50.
| PN | Description |
| 8382966-2 | M101 Vinyl Cover Camo |
| 4020861 | CUCV Transfer Case Adapter |
| 8757809 | 5 Step Aluminum Boarding Ladder Sold |
| 800 Series Air Pack (NOS) | |
| CUCV 6.2 after 95 Cylinder Head | |
| 2910011500950 | CUCV 6.2 Injector Set (NOS) |
| Shifter | |
| M880 Tow Adapter (Set) | |
| 28MT | CUCV 24 Volt Starter NOS |
| 2/5 Ton Mud Flap Set | |
| Load Tamer Cargo Net: No Carabiners | |
| Tent Pole Kit | |
| CUCV Bumper | |
| Winch Cable End | |
| CUCV Bumper | |
| CUCV door Passenger | |
| CUCV Alternators Rebuilt | |
| 14038644 | CUCV Throttle Cable |
| 12447175 | HMMWV 4L80E Transfer Case Adapter |
| 14066255 | CUCV Fuel Ignition Idle control (NOS) |
| 19168610 | HMMWV Water Pump 6.5 (NOS) |
| 23500012 | HMMWV 6.2 Coolant Crossover |
| Wrecker Chains | |
| CUCV maintenance kit | |
| CUCV Mirrors Set | |
| Pressure Plate | |
| 26000060 | CUCV Vacuum Pump |
| 2910011500950 | CUCV 4 - 6.2 Injectors (NOS) |
| CUCV Brush Guard | |
| CUCV Injector Lines (NOS) | |
| HMMWV Oil Dip Stick Assembly | |
| CUCV Power Steering Pump Assembly | |
| 6620009935546 | 2/5 Ton Oil Pressure Sending Unit |
| AA52508-1 | Battery Gauge (box only) |
| MS24543-2 | 2/5 Ton Temp Gauge |
| MS24544-2 | 2/5 Ton Fuel Gauge |
| 2 Can Holder Assembly | |
| Flag Bumper Mount Kit | |
| 14057219 | CUCV TH350 Transmission Vacuum Valve (New) |
| 6.2 Oil Pump (NOS) | |
| HMMWV water pump (NOS) | |
| CUCV Front Grill | |
| CUCV Mirror Set | |
| HMMWV Seat | |
| CUCV Pintle Hitch | |
| MS24537-1 | 2/5 Ton Temp Sending Unit |
| 66022 | 2/5 Ton 24V Starter Solenoid |
| 10948079 | M35 Outer Bearing |
| 12554488 | HMMWV Throttle Position Sensor |
| 14028917M | CUCV 6.2 Coolant Crossover |
| SP0930-95-M-1029 | CUCV 24v Glow Plug Relay |
| Tent Pole Bags | |
| 2/5 Ton 24 Volt Engine Starter Switch | |
| 10872023 | M35 Lower Radiator/Upper Hoses Kit |
| CUCV 6.2 Pulley Set | |
| 23861 | HPCA Solenoid |
| 1114373 | 2/5 Ton Starter Solenoid |
| 12338780 | HMMWV & CUCV Oil Filter adapter 6.2 |
| 26214 | CUCV Stanadyne 6.2 Shut off Solenoid (NOS) |
| 5330-00-075-1764 | M35 Axle seal deuces |
| 5930-00-898-0500 | 2/5 Ton Rotary Switch |
| 6616 | CUCV Starter Solenoid NOS |
| 6A84 | CUCV Glow Plug Spares |
| 974-1215-010-09 | CUCV Glow Plug Relay (NOS) |
| MS24537-1 | 2/5 Ton Engine Temp Sender Kit (NOS) |
| MS-53000-1 | 2/5 Ton Dimmer Switch |
| TS6059 | CUCV Engine Temp Sender (NOS) |
| 12 Ton Bottle Jack | |
| HMMWV Jack | |
| CUCV Front Shackle Mount | |
| CUCV 3 belt kit | |
| Transfer Case Mounts (set) | |
| CUCV 6.2 Intake | |
| HMMWV Intake | |
| 25036797 | CUCV Engine Coolant Temp Sender Kit (NOS) |
| Heater Control Assembly | |
| CUCV Motor Mounts Kit | |
| 19207-8738032 | M35 Inner Wheel Seal |
| 3110010308475 | Tapered Roller Inner |
| 8097 | CUCV Power Steering Pump Seal Kit (NOS) |
| 24 Volt Hella Lights | |
| Battery Hold Down | |
| CUCV Exhaust Manifolds | |
| CUCV Fan Blades | |
| Temp sending unit | |
| 14050445 | CUCV CDR Crankcase Hose (NOS) |
| 23861 | CUCV Stanadyne 6.2 AIR/Fuel Solenoid (NOS) |
| 358-180 | 5 Ton Thermostat |
| 3882979 | CUCV U joint Position Holder |
| 55883 | CUCV Choke 6.2 |
| 5743751 | HMMWV Transfer Case Output Seal |
| 6264100 | CUCV Radiator Mount Pair |
| Q-387AS-382A | CUCV Inner Bearing |
| TM59A | CUCV Transmission Modulator (NOS) |
| CUCV Jack | |
| Jerry Can Holder | |
| CUCV Shift Housing | |
| Pioneer Rack - Shovel | |
| Pioneer Rack - AX | |
| Pioneer Rack - Maddix | |
| CUCV 2 belt kit-alt driver/pass | |
| 2/5 Ton shift boot | |
| CUCV Starter Bracket | |
| CUCV Headlight Bezel | |
| CUCV Starter Mount Bracket (USED) | |
| Slave Adapter 2 Pin | |
| CUCV Exhaust Doughnuts | |
| CUCV Injector Guides (Set) | |
| CUCV Headlight Pairs | |
| M1008/09 Gun Mounts | |
| 6264100 | CUCV Radiator Mount Single |
| ms51915-29-2 | Output shaft seal |
| CUCV Lug Nut Spares 4 pcs | |
| CUCV 6.2 Oil Filters | |
| CUCV Transfer Case Ground Guard | |
| Wrecker Boom Ground Support Assembly | |
| 3/4 " Tow Pins (NOS) |
For you Kenny 5k for everythingThat is a ....."robust" list Swiss. $50 for everything? Depending on price, I might have to need the 28MT starter. Several other items have piqued my interest.
For What??? Reason I asked, just found a pretty nice used M939 5T 3 color cargo cover, rubber rope gone $200 OBO on Saturday ain't coming homeI need a 3 color tarp
I'd like to get the ladder.For What??? Reason I asked, just found a pretty nice used M939 5T 3 color cargo cover, rubber rope gone $200 OBO on Saturday ain't coming home
5 step aluminum ladder NOS. $100
![Thumbs Up    [thumbzup] [thumbzup]](https://www.steelsoldiers.com/images/smilies/icon_smile_thumzup.gif)
I would like one. I PM you last minute. Mess up here in NC, but I am cleared hot for the trip! ETA Thursday PM.I'm packing now and chopping at the bit to get up there. As I said before I am packing light and only one person has said he wants one of Hemtt air ride seat. If no one else says they would like one or at least would like to see one then I will only bring one extra. Good time to get one or two as no shipping so break open the piggy bank guys. Tanks
Do you have anymore aluminum ladders? If so I'll take one. Sorry noFor What??? Reason I asked, just found a pretty nice used M939 5T 3 color cargo cover, rubber rope gone $200 OBO on Saturday ain't coming home
Sure, you bring the V100 and we'll trade.Can someone bring me a few thousand dollars?
| 11664387 | Clutch Disc For 5 Ton Trucks M809 and M54A2 (M39A2) Series |
| 8735507 | Pressure Plate 5 Ton Trucks M809 and M54A2 (M39A2) Series |
| CUCV 1010 & 1028/205 Transfer Case Shifter |
| M100 Landing Leg taken off my M100 |
