24 volt horn...bought on ebay
isaiah
honolulu.hawaii
This horn was just bought on ebay cause the NAPA one I bought burned out when I hooked it up directly to my battery...worked for about three blasts then went dead. with these ones rated 24volt it should work right?
This is how the seller described it on EBAY.
heres the link also
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=ADME:B:EOIBSAA:US:31&Item=300242355394
This is a multiple identical item listing for 24Volt 355 Hz Military Surplus Horns. Each bid quantity is for One (1) Horn. You may bid / buy any number, up to the total quantity available above.
Nothing says "Here I am! Shoot me!" like a good noisy horn on a military vehicle. Just the thing to raise public awareness of those clandestine operations that otherwise seem to go unnoticed. Simply connect the 1/4" spade terminals to a convenient 24V power source, throw the juice to it, and you'll stand out like a hooker at a family reunion.
These were made in Germany and the quality is superb. Among the assorted numbers is written: FER BELMA. I'm not sure what that means, but it would be a great name for a company that manufactures horns. They have a frequency of 335 Hz, which is probably considered a very "low note" or bass horn (as compared to the higher pitch used on passenger cars and such). Since they were shipped in bulk, there is an occasional paint scratch but all are cosmetic.
Overall diameter is 3-7/8" and they are about 2-1/4" deep. The mounting bracket is .875" wide, .110" thick, and it has a .420" diameter mounting hole.
AJMBLAZER
Paducah, KY
The CUCV horn is a standard GM 12v horn of the era and only gets 12v so at best that thing will simply sound like a weak or dying horn. You'll only be giving it half the power it was designed to receive.
CCATLETT1984
Saint Clair Shores, MI
or you can use the one you got, you have to hook up a relay that is switched from the original horn wiring. and run power from the 24v buss bar on the firewall to the new horn through the relay.
Bozor1000
Riverside, CA
Thata's what I figured that the stock horn from the factory was 12 volt not 24. AJM, I think some guys need some educating over here also as to the volt system of a M series truck.
TedG
39
MI USA
That looks like a Claxon horn, used on ma-3d portable ac units for alarms. It also might be used on Unimogs for it resembles them. They are very LOUD! 24vdc typically.
regards,
isaiah
honolulu.hawaii
Re: RE: 24 volt horn...bought on ebay
msoumas said:
If you get one, let me know how it sounds. :D
Just like what the EBAYER said...
Thanks for your answers I connected the wire direct to the battery and grounded the other hooked up a push button and it worked.
You may be right about getting half the juice, but it sounded quite loud enough. I just don't understand why the NAPA horn failed after a few bursts. I just thought it had too much juice.
Have a nice day!
