250 cummins fuel in oil
1,193
It may be a simple O ring or gasket. The fuel goes between heads in a tube.
Pull the valve covers and look for a loose tube.
The whole fuel system is always pressurized and the injectors are mechanical.
laxcc18
Leonardtown MD. So MD
Thank you I'll try see if I can see anything . I was trying to find info I saw some stuff about injectors staying open but not sure if that would dump fuel into the oil as well
wrenchturner6238
35
Beaver Oklahoma
The best way to find the leak remove the valve cover remove the return line, get a bottle of florescent dye mix up a gallon of fuel with dye install a pump to build some psi in heads you will need to flow some dyed fuel first. (hand pump like the prime pump that is on the truck) pressure up the system and take a black light to find where the leak is. You will see some seepage from all of the injectors but you are looking for a big leak. I am not sure how good of friends you are with your local truck shop but the most likely have all the stuff you need and possibly let you barrow a black light and by the dye from them.
1,193
Look up the part number in the TM, and then google it.
Or go to your local Cummins shop with your engine info.
Suprman
707
Stratford/Connecticut
You can call cummins and give them the engine serial number from the metal data tag on the timing cover and they can tell you all.
Suprman
707
I just told you what to do. Call Cummins directly and give them the engine serial number they will tell you what parts and you will be able to order them from Cummins.
wrenchturner6238
35
Beaver Oklahoma
You might be able to take your engine S/N and CPL #'s from the data plate on the engine and call or go in to the Cummings dealer and have them look it up the o-rings should not be that expensive even from the dealer.
1,193
Which TM you been looking in?
This seems to have it.
1,193
If you're looking for item #17, it is Cummins part number 3007759.
laxcc18
It did indeed end up being an bad o-ring on one of the injectors. I went ahead and bought a couple of injector re-build kits off e-bay to fix it up. Doesn't seem to leak anymore just working on getting the timing adjusted on the pump so i can get it back on the road. Thanks for the help everyone!
