3/4 to 1 ton axle swap build
welpro222
Bellingham, WA
Hey guys, thought I would post up my quest to put 1 ton axles under my 87 suburban. The front is getting a dana 60 4.10 gearing with a dana power lok differential. The rear is a 14 bolt 10.5 ff with the gov lock differential. I'll keep posting as I make progress, at the moment I'm getting ready to remove the 3/4 ton axles and just prepping the new ones (clean and paint). Other than that, all new seals and bearings for the rear and all new seals and king pins for the front.
Here are some pics, let me know what you guys think or if you have any suggestions.
welpro222
Bellingham, WA
Already done by the previous owner. The only thing I was worried about is the pinion housing length difference between the 14 bolt sf and the 14 bolt ff. I am gonna measure it tonight.
welpro222
Bellingham, WA
I removed the front and rear axle yesterday. Will spend the week cleaning and painting the wheel wells and other parts. Still debating on whether to go with the crossover steering setup.
