335 Cummins Knowlege?
mightyhammer
Lewiston, ID.
I have caroused the Pittsburgh Power write up on Cummins power upgrades and there ain't much there for 335's. Does anyone here have any experience with 'em or a vast knowlege of them or where to find info about? I have a real nice one that came out of an old Mack Yarder that I scrapped, and I will be putting it in my wrecker someday here soon. I am pretty sure they are very clost to the 350's with a small mod, but not sure...
WillWagner
2,396
Monrovia, Ca.
Parts are getting real hard to find. The 335 is a fossil compared to the NHC...and it's a dinosaur!! My 2cents, leave the 335 alone, look for an NHC or better yet an NTC.
Bolkbich
MAHWAH, NJ
Bigger turbo and a different button in the pump. The 335 is a great engine. Call pittsburgh diesel, they'll set you up. I had one in an autocar dump ,480 HP pulled like a monster. I worked it everyday.
mightyhammer
Lewiston, ID.
Yea, Will, I hear ya. I have a BCII that I am building, but just for now that 335 should be fine till the 400 is ready. That dang 250 is just too puny for a dang 35000lb. wrecker, let alone a cargo truck. The 335 I have has only around 400 hours on an inframe when it powered the yarder. I just don't have a lot of info on it cuz, like you said.... It surely is a dinosaur! I have heard that they were a pretty good engine in their day, just wasn't sure what the difference was between it and the 350. Thanks Bolk for the info!
JH1
Seattle, WA
The 335 has piston coolers, so you can potentially crank it up to 400 HP. Set the pump higher, get the larger injectors. I think it would be a good engine. If you put a commercial 335 into a mil truck, you'll need the offset bell housing (mil Cummins engines sit to the side a bit to clear the front driveline) and a slightly different oil pan that has to miss the pumpkin. I have an offset belll housing and mil oil pan I'd sell if you need them. Located near Seattle. Also have the front motor mount, which is also offset a bit.
Jim
