4l80E
panzerwillie
303
miami florida
Grtting ready to replace my 3L80 with a 4L80E i think i got everything i need ,does anyone know where to get the corect dipstick for the trany that is for when going in deep water like the one on the 3l80 before i cut and weld
thx
TedG
39
MI USA
Willie, I hope I am not too late on this.
To my knowledge, the 4 speed bayonet is similar to civilian ones. The 3 speed had a special water proof setup when the dwf kit was added. Get the 4 speed setup from an H1 or kashcar. The 4 spd tube/bayonet is much longer also.
panzerwillie
303
miami florida
thank you for the reply got that taking care off i made one out of both now could you help me with the rear drive shaft maybe you can measure yours from senter cup to center cup like to get it done before i start to take it apart thank yourofl
TedG
39
MI USA
My ECV 6.5td with 4spd is sold and no longer on site so no measurements possible. With a 4 spd, you should use the 242 tcase with new cross-member to support the entire setup. Since this set up is longer (due to the 4spd), then you need a new rear propellor with slip yoke. This would be a standard prop unless you have the pinion parking brake (you may need to remove that brake and go with disk brake calipers with parking brake mod). Also, you need to replace the front propellors (at least the one attached to the tcase) since the tcase sit further back.
If you are going to leave the 218 tcase (I do not recommend this since the 242 is much more durable and smoother in the hmmwv), then just have the propellors professionally fitted.
Confused yet?! lol
panzerwillie
303
miami florida
never confuse aua, i have evrything of a H! minus rear shaft the idiot cut it for another job did i mension the idiot cut it, never the less my truck has already a 242 tranfercase with rear brake calipers, it came standar like that is a 91 all i need it some one with a HMMWV here in this great website that has a 4SPD that can give me center cup to center cup measurements after all my calcualation my 3l80e with slip type yoke is 2 inches shorter than the 4l80e with the same 242 , i have another shaft ready to be modified thanks
TedG
39
MI USA
I drove that truck you are wrenching on! Came from DE and now in FL. I may have the rear propellor but it will be more than a week before I can get to it.
panzerwillie
303
miami florida
i still need the TPS i think 92 or 93 chevy will work and still going to go througth the trany and rebuild it even do is a running unit starting next week so if you find it its mine if you want to sale it
thx:razz:
