2deuce
- 188
- 63
- portland, oregon
Got the clutck out and found the problem. The pilot bearing had disintegrated and the rollers, & pieces of the race have ground up between the flywheel and disc. The only thing left of the bearing was about 3/4 of the outer race, everything else was ground up except about 6 or7 rollers which were bouncing around in the open area where the flywheel bolts on. I have only moved the truck by backing it up my driveway into a building which was about 100'. I'm lucky that the clutch worked when I was parking the truck or it would have tried to go through the wall of my building before I knew I had a problem. There was no noise or feeling in the clutch while I was moving the truck, but the prior owners I would expect would have known there was something wrong in there. I'll try to get a picture of the disc.
The flywheel needs to be resurfaced. I have removed the bolts but I will have to buy a puller. The bolts were safety wired. Is it necessary to do this when I reinstall? The RPM's arent that high and I haven't seen that in cars. I'm wondering if locktite would be OK instead. Also can anyone tell me how tight to torque those flywheel bolts when it goes back together? Thanks, Greg
