5 ton dump what is it worth
todd1874
fargo ND
new member wanted to know if a 5 ton dump truck in 75 % condition is worth $4000? little rust glass all broke hard top. missing tailgate and spare tire rack needs tires
pa.rich
If it runs good, has brakes, tranny shifts well and doesnt jump out of gear, not rusted badly. I think its worth the 4k. Try out the dump body hoist with a load on it and go from there. The control box on these dumps can be the weak point when they are worn out. Check the pistons for leaks when using the hoist. About the tires, most of these trucks have old weatherchecked tires and should be replaced . Used ones are easy to come across. The glass, just buy some used inner windshields and for the doors, replacement glass is available used. In my case it was cheaper to replace the entire door than mess with the glass replacement. And another thing is where you are located. If there is a good selection close to home, look around. If there isnt, transporting these is expensive. In my case there were none nearby so I paid more than most guys would for it. Long story. Good luck, and if you purchase one you will love it. Especially the power steering.
