5 ton heater pics
leecarr
Rochester, MA
Does any one have pictures of under the hood of a 5 ton cab heater installation? I would like to see where the hoses come from and are run.
BigWill1985
Norfolk, VA
I can snap you some pictures tomorrow of my M817. It has a complete, working heater system. That thing gets so hot it will cook you out of the cab! Really impressive with all of the "vent holes" (a.k.a.: leaks) blowing in plenty of cold air!
What specific truck do you need pics of?
~Will Courtier~
MO MV man
Imperial, MO
Heater Core Hose location.....
I snapped this picture today.
My core is leaking slightly so I'm going to replace it.
Wanted a picture to compare the inlet location.
At least this will give you an idea of where the hoses are on the heater box.
The bottom of the pic is the firewall and this is looking straight down on the unit.
Hope this helps?
My truck is an '84 M923, by the way.
BigWill1985
Norfolk, VA
I imagine he needs pics of the entire hose routing. So, he needs a higher picture of the hoses from the engine, to the heater core and back to the engine (showing the hose routing). Might be best to get a photo of each heater hose independently so he can get a good image of the routing of each.
~Will Courtier~
MWMULES
344
DESOTO, KANSAS
Here you go for valves from a M923 same place on engine for a 800, just pulled one of these heaters last week out at BFR Metals to mount inside the cab on my M275.
EMD567
Driver for the Ga Mafia
46
Aiken SC
Here are the ones from my M814.
As you can see, I have the front routed to the cold side, and the back to the hot(top) of the engine.
leecarr
Rochester, MA
I'm working on an 813, just bought a NOS jeep heater from an army surplus place for $70.00 and we're going to adapt it. I have all the interior duct work and diverter. More interested in the defroster than heat, this is going to be a working truck and I need to see where I am going. I am interested in where the hoses originate on the engine, found a couple of spots bit i would like to make sure they are correct to allow for proper flow.
Thanks everyone for the help.
