5 ton m925a2 headlight replacement
hokie8358
backwoods ,virginia
wondering if you can pick up a 24 volt wagner headlight with the correct male ends on the back from a napa store or local parts shop?
my low beam on my 93 model 5 ton gave out right before my inspection today. and of course they would not put sticker on it.
my part number on light is 5A910 on the back. this is my first rodeo on the 24 volt lights. my napa store had the 623 parklights.
any help would be great. thanks
mkcoen
381
Spring Branch, TX
The quick answer is "no." I've heard of folks taking the plugs off old lights and soldering them on to new ones but have no real world experience to give you on that. That alternative is go to one of the Vendors on here and order a replacement or find someone locally that might be parting out a deuce or 5 ton that has some useable lights.
CNKILLERCLOWN
Hernando, MS
Make some buddies at the local motor pool. In the past I gave em the old one and they spotted me a new one. Granted I use my truck for state business so I am not sure if that had anything to do with it or not. You could always ask. The worst they could say is no.
SUPERSPORT
Ohio
Buy the 7" light (6024), Dorman 9003 socket, and a pack of female bullet connectors all from any auto parts store. You can order the military weatherproof connectors and add those later if you want.
capnkirk
Miami, OK
Second on hklvette's reply. Best thing I ever did. Bought them on amazon cheap. You can use standard (24v) halogen bulbs which are cheaper than the sealed beams when you replace them. Soldered the civilian lamp socket to the old leads I cut off the dead sealed beams.
hokie8358
backwoods ,virginia
I looked on the amazon site. you referring to the 7 inch hella light conversions to halogen bulbs? if that's the case,yes your right ! lights are only 29-43 bucks a piece.
then do the wire harness conversion to the civi harness plug and run 24v bulbs! sweet!
plode
South Jersey
I got a Wagner replacement bulb at Napa, unsoldered the pigtails w/connector off of the military headlight, and soldered them onto the new one. No issues with it so far.
capnkirk
Miami, OK
Exactly hokie! Buy the hella conversion (it comes with 12v lamps). Buy some 24v lamps, ceramic sockets. Solder the old pigtails and you're done! Next time you need to replace a headlight, you just need the little halogen lamp. Much easier to keep a spare in the truck than the fill sealed beam lamp.
Those Military Guys
Rancho Cucamonga, CA
we sell the stock lights and the h4 conversion headlghts for the trucks if you ever need replacement parts or want to upgrade let us know and shipping is free so if we can ever help let us know
thanks
TMG
