56 reo front axle sprag
bulldog_mack13
3/3 ACR
2,969
34
Colo Springs, CO
Your front axle only works when your rear tires slip. Do you have a tree near you that you cant pull down with your truck? Tie your Deuce off to the tree , have someone watch the wheels and start to move , have them watch to see if the front tires start to pull. Do the same in reverse.
If not then it might need to be adjusted or might not work at all. -Jay
Barrman
1,610
Giddings, Texas
Keep your fingers and thumbs out of the steering wheel when you do this. The front axle engages when the rear tire achieve a 6% spin. Then, presto chango, the front tires are spinning. If the wheel is turned, one tires gets good traction or something like that. Then the steering wheel will spin in your hands. Thumbs up and pinkies down will save you.
The theory is that the front will engage before the rears start hopping around. If your rears are hoppin around and spinning with the front never even engaging. Then you need to download the pre 1965 -20 manual for the M35. It walks you through how to adjust the sprag and how to test it. The official test does not include a tree or spinning the rear tires by the way.
wdbtchr
St. Louis, MO
I use a steep hill out in the woods, just try to go up forward or reverse. If the front axle engages I can go up or down.:roll:That way I don't need a second person to watch the front wheels.
waayfast
106
Lake Fork,Idaho
First, welcome to the site!When the guys speak of the "TM,s", they mean the technical manuals. Lucky for you(all of us:)) the site has provided for free the TM,s.
Look at the top of the page --find and click on "resources",second line down--Tech Manuals.
Happy reading and enjoy!
JIm
