6.2 cylinder head application
Tanner
11
Raleigh, NC
HOWEVER; if you are replacing one busted cylinder head on an engine, it needs to match the other head on the engine, in regards to valve sizes, chamber size, etc...
'Tanner'
chevyCUCV
Massachusetts
Did you buy those off of GL?
I see that an auction ended with 7 heads brand new for 591.00
Thats a sweet deal
And i would replace the heads in pairs to avoid any difference that there may be (c or j code, or for 6.5 will have different precups i.e. slightly different compression)
jdeoliveira74
wilmington nc
ok here is a question are 6.2 l heads less restrictive then the 6.5 heads?? I have a 6.5 navistar sitting in the crate and if thats the case i will put the 6.2 heads on it. But to me that doesnt make much sence.
