6.2 oil pan torque specs...
Matt Kahle
germantown NY
I was wondering if any one here can get me a check list for the oil pan torque specs. I remember seeing some old post on 6.2 ,but can't find them.
Okay I know you guys are going to say read the TMs. I really can't scroll around the TMs through different pages for spects with oily hands. :? Thanks for any help.
Warthog
240
OKC, OK
The manual doesn't list any torque specs for the oil pan.
There is a paragraph in the PMCS section that says to check the oil pan bolts semi-annually and tighten them to 5 ft-lbs.
There is a list at the back of the TM 9-2320-289-20 that has general specs
Looking thru the 6.2L/6.5L HMMWV egine manual TM 9-2815-237-34 it shows 48-120 lb-in for the side screws and 156-240 lb-in for the rear main screws
Speddmon
Blind squirrel rehabiltator
30
Cambridge, Ohio
Just in case you don't have a torque wrench scaled fo lb-in, there are 12 lb-in and 1 lb-ft. Just like measuring distance 12 inches per foot.
