6.2L piston rod side play
Curtisje
698
Okinawa, Japan
While replacing the rear main seal today I noticed that I can 'click' each set of rod mains side to side. Is this normal or do I need to replace the bearing?
cucvmule
collector of stuff
1,165
597
Crystal City Mo
Having clearance, as in side to side movement of connecting rods is more when engine is cold. When engine gets hot the connecting rods expand closing up tolerance. Using a feeler gage the clearance is between rods at .007-.025,.
Now that engine is worn that clearance will be more, but the bearing is more critical at the bearing surface to crankshaft surface measurement.
Curtisje
698
Okinawa, Japan
Thanks cucvmule. I'll be hooking up a pressure gauge like dependable suggested. The engine has 38,000 miles on it. I appreciate your insight.
Curtisje
698
Okinawa, Japan
That is normal. If you think you may need to replace bearings, test oil pressure first.
Don't want to take a good OEM engine apart if it is working fine.
Hooked up the oil pressure gauge today. 50 PSI cold idle. 25 PSI hot idle. 50-55 while driving. I think everything is ok.
