6.5 ip with 6.2 injectors
itsunday25
pennsylvania
k i got cucv i put a new 6.5 ip in my truck but i left the 6.2 in injectors in it will i get more power if i put the 6.5 injectors in it or should i just leave the 6.2 ones in it thanks
dstang97
33
Clover, SC
It all depends There a 6.5 NA and turbo injectors. The 6.5 pump can put out more fuel than a 6.2. If you do not have a turbo you can put in 6.5 injectors but make sure you detune your Injection pump. There should be the tinyest little puff of black smoke under hard acceleration. If I had to guess I would say pump maxed out back off 3/8
