60 amp m35a2 genarator rebuild? ?
papakb
1,186
San Jose, Ca
Most good electrical shops can rebuild them for you. If it's one of the Leece-Neville units the regulators are up on ebay all the time for around $60. Six screws and your done. I always recommend replacing the brushes at the same time and blowing out the regulator cavity because carbon from brush wear will build up there. Brushes run less than $10 and it's 2 screws to install them. If you want to do it yourself everything is available from Southern Automotive at this website:
http://www.southernautomotive.com/catalog/product_info.php/cPath/22/products_id/29
Take a look around their site and you can find technical info on rebuilding and testing your charging system.
Kurt
Wildman35a2
Tazewell Tennessee
Thanks I lost power Tony harness when I opened the genny it was toast screw heads almost in recognizable got a used one from eBay but still have no power coming in to my wiring harness
Wildman35a2
Tazewell Tennessee
Mine isn't putting power into my harness I replaced it headlight to taillight purchased one from eBay but still have no power coming in to my wiring harness have power to Genny nothing to the rest of the truck
