8 lug to 6 lug
billybronco1
Richmond, VA
Title says it all. Have a buddy willing to swap 6 lug 16" wheel and tire for my 8 lug 16.5" wheel and tire.
How is it done? Can it be done? Simple as pull the hub and replace? Can't be with milspec, right?
Adapter? Need a bombproof solution! Thanks.
1,823
Well, what kind of trailer and why? Only swapping one wheel and tire? What are you planning for the other one?
billybronco1
Richmond, VA
tire"S"
Plural. Many. MANY apologies kind forum folk.
I beg of you.....
I have TWO wheels and TWO tires. Both brand new and attempting to trade BOTH. That's a total of TWO. for. BOTH. for his 6 lug pattern wheels and tires.
For what u ask? Leave that to me. Nothing more than the military I can assure you.
Thank you kind SIRS.
gringeltaube
Staff Member
2,654
Montevideo/Uruguay
Welcome to Steelsoldiers! I see you are pretty new here...
Might want to consider a few points:
1) If you really want to be helped then better be more specific about what model trailer you want to convert.
2) "U" is a vocal which we may use to describe the type of bolt; joint; etc. "U" is not allowed to use in place of the word "you". (re-read our house rules.)
3) You'll need to work a bit on your attitude, too. Better start soon (if you intend to stay here...)
G.
1,823
There is no easy way short of buying a new axle or just buying 8 lug 16" rims and swapping over the traded tires. We have answers here but only CARNAC is clairvoyant.
cyclic
central Texas
I'm fairly certain you can swap the outer drum assembly to six lug. As backing plates and drums interchange with the regular 6000/7000lb axle stuff.
The backing plates can be swapped to electric with or without parking brakes.
Standard Dexter axle stuff.
