jimm1009
- 71
- 48
- Louisville, KY
Too fast for quick stopping. No matter how good your tires are or your front end alighmnet 98% of all M1009 trucks will fish tail to the right when skidding.
The olnly way to pull out is to release the brakes and that can lead to other problems (BANG).
If you have 33 inch tires you can comfortably run 70 MPH with a tolerable engine RPM but that speed is too much for engine to stay healthy with standard 31 inch tires no tto mention the MPG above 70.
The OEM M1009 shock setup is two on front and if you have the civy option of Quad Shocks (2 per side) then this helps the nose dive that is prevelant is diesel powered Blazers & Jimmys too.
Stay a little slower and stay healthy and alive.
jimm1009
jimm1009
