802 803 831 Hi temp switch Problem
Steel Soldiers is supported by:
PoP PoP
Cerro Gordo NC
802 803 Hi temp switch Problem
My new 803 has a bad Hi temp switch. This is IP, GP purchase, it came in with the wire unplugged. (New Machine 07 model) It reads open which it should as well as the one on my 802. When connected it will send the genset into HI Temp fault. Swapped out with the 802 and of course the 802 now has the fault and the 803 is good to go. My problem is finding a replacement at a reasonable price and of course the lesser issue of it showing open (which it should) yet causes the fault. I can live with not understanding. What and where do you guys use for replacement? Found Horton 220 F switch that I think will work but wanted to ask here first. I would be happy with a used one that is known to work. Should say inbox me with used switch price please. The switch part number is OEM MEP802A-MEP803A TEMPERATURE SWITCH Onan 186-6581 The switch itself is labeled (INDEX 8037122) Just for clarity this is the 2 wire Hi temp Switch NOT the temp indicator sender MT 6.
PoP PoP
Cerro Gordo NC
I was hoping someone would give a link based of their independent search. So I will throw out what I found. Is this correct, even if it is 5 degrees cooler? 220 F vs 225 F I think it would not make a diff. Deleted link to avoid mistake or confusion. Thread diameter could have been diff.
Zed254
139
South Hampton Roads, Virginia
Searched on your posted part numbers. The onan didn't get me much. The INDEX 8037122 number has more info available.
https://www.ebay.com/itm/INDEX-Ther...Thread-225-Degree-Normally-Open-/252688737382
Then did a reverse search on the NSN 5930-01-378-6882 in TM 9-6115-642-24P and came up with:
9 PAOZZ PAOZZ PAOZZ 30554 88-22203 .SWITCH,THERMOSTATIC 1 1
Then searched on parttarget with the TM's part number: https://www.parttarget.com/5930-01-...&searchoption=sku&originalsearchtext=88-22203
NSNs match. I think your part is the ebay listing.
PoP PoP
Cerro Gordo NC
​How in the world I did not see that listing. I searched and researched. WOW! It comes up first when I searched for it! Just WOW. Thank you Zed254 Part ordered.
