Greg Elmgren
- 1
- 1
- Richmond Hill GA 31324
<strong>
803 Starting Issues</strong><br><br><font color="#E6E3D9"><div style="margin-left:40px"><strong>803a I am having starting issues. I hold the switch it will not </strong><strong>start. I can dead crank it if I zip tie the fuel solenoid open. The convenience receptacles do work at this point. It has cranked and ran sporadically. But now it just clicks. It does throw the low oil pressure breaker. I have checked the oil tube to the sensor by removing the sensor oil did shoot out as i turned it over. I sprayed the unit down with electrical cleaner It cranked for a bit then stopped 2 hours later.(This ruined the plastic on the gauges. I had to super glue them back until I find some.) The fuel pump does work until I turn it to start. then it cuts out. thanks in advance<br>
<br>
</strong><img src="images/smilies/tigger.gif" border="0" alt="" title="Tigger" smilieid="146" class="inlineimg"></div></font>
<br>
