803a Metering Pumps, Random Questions
Iron.Horse
27
13
Frederick, Maryland
Good Evening Guys,
I have a couple questions that have me a little stumped.
First of all, I have a engine that is pulled from a 400hz unit that is intended to be a donor motor for a 60hz machine with a bad engine. Upon investigation of it, I found that the fuel rack was stuck and I figured that the pumps could use a good cleaning. I have pulled plenty of fuel pumps out before and figured it wouldn't be a big deal. After soaking them for a while, I started reasembly and figured out after a while that slot/pump "3" wasn't cooperating. Every time that pump was introduced into the line-up it caused the rack to have issues. I played with it for quite a while and have ultimately figured out that the internal plunger that pushes up on the fuel pump spring (and thus creates the pumping action/pressure) is in a slightly elevated position not allowing the metering pump to sit down where it is supposed to. I have read that by dead cranking the motor it should change the position of the plunger, but turning the engine over by hand via the front pulley didn't change it's position at all. Is there a reason dead cranking would produce a different result? How else would I get the fuel plunger down? I did spray PB blaster in there to see if it would free up any.
Seccond, I have a unit that I am chasing the elusive "no power" (well actually 30 or so volts, but it isn't field flashing to produce power). I have done VR testing but the readings are all over since there isn't sufficient power to it. I know the OHM testing of the stator (per the TM) is difficult becasue of the tight tolerences and "lower quality" volt meters... At what point do you pull the gen head apart to check the individual components? I believe this was a non-fuse modded unit, so I wouldn't be totally surprised if something is messed up internally.
Also, is there any reason not to use a good engine de-greaser and either wash out or gently power wash the engine bay of a couple fully assembled units that are fairly dirty from leaking fuel lines? I would normally shy away from any water in there but it seems like that is the only way to get rid of the oil residue. I am well aware of not introducing cold water on a hot engine, but my concern is more of the electrical connections...
Ray70
7,205
West greenwich/RI
Dead crank Vs. turning by hand are no different. If you turned the motor a good 90* or more and the cam follower is still holding the metering pump up more than 1/8" - 3/16" off the block, then I would suspect it may be stuck. Hopefully the PB blaster trick will free it up.
Lets get it running right before chasing the voltage output issue.
I steam clean every generator I get, inside and out, but hot water dries faster than cold so I'd suggest blowing out all the little crevices with compressed air of a leaf blower when you're done.
Iron.Horse
27
13
Frederick, Maryland
So I'm still not getting this fuel metering pump to seat. I've put PB Blaster down the hole and clean motor oil, tried turning the crank to all different positions while putting my finger down there to feel if the plunger is moving, and nothing. Is there anything to freeze up or break inside the motor that would cause this? The unit had an oil change/filter in 2019, and appears to have around 690 hrs on the clock. Compression is nice and tight. I even tried a different metering pump to make sure there was no difference. The only thing I can think of at this point is to actually run the machine on 3 cylinders or dead crank and see if the repetitive motion might jar it loose similar to an impact? I am just hesitant to finish assembling the machine if the motor has a internal problem, but I also find it hard to believe it is that messed up...
Iron.Horse
27
13
Frederick, Maryland
Light in the Dark
6,808
MA
Maybe the tappet is stuck/unmoving. This is a gear driven front end, with the tappet riding right on the cam shaft, super simple setup. I would pull the problem pump position in question, and see whats down the hole. Spray and heat liberally.
Iron.Horse
27
13
Frederick, Maryland
Thanks Light in the Dark, I really appreciate it. I am quite sure you are right that the "tappet" is stuck. Do you think running the machine might loosen it up any? I did get the metering pump in, but only because the clamp is holding it down/depressing the spring. I am confident that I got it lined up correctly and the rack is moving, but I know that one at minimum is stuck, so it may just not push fuel to through that pump and to the injector. I definitely have soaking products in there...
Ray70
7,205
West greenwich/RI
Do you happen to recall how things were when you removed the #3 metering pump? Did it pop up that same amount when you removed the clamp?
I'm almost wondering if someone in the past somehow put 2 of the cups ( #6 in diagram ) in instead of 1.
I assume you've cranked the motor at least 2 full revolutions or more, and you aren't seeing any movement up or down?
If so the cam follower has to be stuck.
If you have a borescope I would try removing the #2 pump and get a borescope in there to look at lifter #3, perhaps you can see what's happening in there?
Iron.Horse
27
13
Frederick, Maryland
Hmm that's an interesting thought, I honestly don't remember how it came out, the rack was all sorts of jammed up and I was more concerned that someone put the pumps in wrong and bent it. I don't have a borescope, but maybe I can get creative. Are we talking about #6 in the diagram? I wasn't sure if there was a retaining system for the cups or whether they just floated in there.
Ray70
7,205
West greenwich/RI
Correct, item 6. IIRC it is just sitting on top of the cam follower. You should be able to pick it out with a magnet, unless it's frozen in there.
If you didn't see any signs of rust or heavy carbon sludge when you pulled everything apart I somewhat doubt the follower or cup is frozen in there.
You can get a cheap USB borescope on Amazon for like $30 and plug it into a laptop.
Iron.Horse
27
13
Frederick, Maryland
Well I had to work today and didn't have much time, but I did manage to get a magnet and pull the follower (#6) out of the trouble cylinder. Definitely only one in there and it came out perfect. Everything looks clean but I soaked it again with PB Blaster. I could probably drop a deep well socket down there and gently tap on it, but at this point am I looking at a full motor tear down to try and figure out what is wrong with the camshaft and why its not pushing the follower? I'm not really feeling disassembling the whole motor right now, especially with so many other gen sets to work on...
LuckeyD
399
Vilseck, Germany
Good Day: Here is a thought I only ever saw once. Those injector Pumps ride in the cups you say are stuck. The cup has a slot in it and a screw is screwed in to keep them in position. See attached and screw number 8. Now compare these screws on your engine. It is possible one has screwed the number 3 in just a bit much or has the cup not positioned correctly and screwed in this screw. Just a thought. Takes a second to compare. This is shown in the engine books from Lister petter in the TM section. Not shown well in the engine TM. Would explain the frozen cup you are unable to free up. No difference on those engines, just the running RPM.
Ray70
7,205
West greenwich/RI
I wouldn't tear it down just yet. You've got lots more to evaluate first.
I really think investing $30 in a borescope would be well worth you investment.
You will most likely be able to see the camshaft and the follower.
You can turn the motor over and see if the cam is separating away from the follower ( assuming the follower is stuck in the upmost position.
I'm a bit doubtful that the follower would be frozen from rust etc. so I'd further investigate Lucky D's suggestion about a mis-installed follower/bolt.
Since you got the cup out with ease I would drop a socket or pipe etc. down there and first crank the motor a couple revolutions and just verify the socket doesn't move. If not, you have to remove the engine side cover to access the retainer bolt ( threaded pin) lucky is talking about. Loosen it and see if the cam follower drops down. With the side cover removed you will have even more access to see up in there with a camera or mirror and see what's going on!
Iron.Horse
27
13
Frederick, Maryland
Ok. So still haven't had much time, but have been following what you guys have suggested. I took the front cover and side plate off of a bad motor (not this one) to see the inner workings. Pretty simple and neat. So my current conundrum is that I took another pump (#2) out of the motor in question and spun the crank by hand and... That plunger doesn't move at all either. So I'm inclined to believe that the crank for the fuel pumps may not be turning at all? I'm really perplexed because I don't see a disengagement of the fuel rail crank from the main one and oil pump, it is all geared together.
Ray70
7,205
West greenwich/RI
The pumps drive off the camshaft which is gear driven off the crank.
You could pull off the last valve cover ( or any cover ) and see if the rocker arms are moving.
I'm suggesting the last valve cover incase the cam is broken near the middle.
A broken camshaft is unlikely, but not unheard of!
