900 series combat rims
steelsoldiers
4,140
Charleston, WV
Dang rims are rare as hen's teeth. I have 4 and am looking for more. Looks like the only way to get a complete set is to buy a residue truck from GL :D I let a 927A1 go last month that had a full set. Final bid was $2550 I think. It had potential. There should be a better supply as more and more of the 939 trucks come out of service.
citizensoldier
19
Northern Michigan. Smelt City
Whhhhhhhhughhhhhhhhhh.. Chugga! Chugga! Been remodeling a old farm house built in the late 1700's, bailing hay, and trying to get these tires mounted.. Finished up the last two today and mounted one more to the truck.
I think I found my wobble problem too.. I had some bad vibration around 45-50 MPH.. Thought it was either a bent rim or a tire out of round.. But! This truck must have been stuck in, or broken through blacktop at one time??? .. :shock: It had tar/blacktop squished between the backplate and the drum on the rear deul tires.. It was caked on the back side and set up... I took a zero degree tip on the old power washer and removed it.. This must have been the out of balance issue..
Cdub
New Milford, NJ
OUTSTANDING.............!!!!!
lub and more lub is the ticket........they're not really a big deal once you done a few.....and they seem to go faster with each tire mounting.......
The truck looks super fantastic.......
Cheers,
C'dub
Cdub
New Milford, NJ
Oh and BTW Chris.......I think I'm going to have to come down to VA and give ya a kick in the Butt for letting that M927a1 USMC truck go......how could ya.......??!!??........it brakes my HART......
C'dub
steelsoldiers
4,140
Charleston, WV
Yeah, I liked it a whole lot, but some big bidder liked it even more. He bought 3 other 939 trucks in the same auction. :roll: The one I was talking about in the post above was an Army truck in PA. The 927A1 in SC went for $4000+ and it needed a lot of work.
steelsoldiers
4,140
Charleston, WV
I was already bidding on them when you sent it. :)
By the way, looking good, Lane!
I found 3 more from a fellow member in FL so I now have a complete set. I am going to sandblast them all and rebuild them with fresh paint, valves and o-rings.
citizensoldier
19
gimpyrobb said:
Lane, you suck.
Man someone has there panties a bunch !! I could not do the last one because the dog ate the valve stem...Bahahahahahahahah..
It took me two years to round up all this junk in ways I could afford.. They wont be on the wrecker long though.. They are for the M51A2 but it still has a sick motor.. Talk about "hens teeth"! That would be a good LDS 4651A..
