900 Series Tire Question
rcb
pittsburgh, pa.
Greetings !!
Won a 900 Series A2 with flat tires, no batteries and parts missing.
Question... so I don't damage the tires, how do you inflate the tires
for hauling the truck up on a flatbed ? Without seeing the truck in
person, isn't the inflation system sealed or can you still air-up at each
wheel ?
Thanks...
Bob
M35A2-AZ
390
Tonopah, AZ
You can air up each tire if they put the valve on the wheels right.
We just pickup a M925A2 and we could not get air in one of the tires.
As it turns out they left a valve core in the tire when they put the CTIS valve on it.
So you could not let air out or put air in.
Good luck with your truck.
Doubled
Jonesboro, Arkansas
If they don't hold air
If your tires won't hold air and you need to replace the O-Rings in the wheels I can refer you to a couple suppliers.
KsM715
142
St George Ks
Are the flat tires on the front? If so I would be very weary of using those tires there. GL will not air up the tires when they move trucks around the lot and often the tires are already shot.
M35A2-AZ
390
Tonopah, AZ
:ditto:
Here is somes pics for my M931A1 we picked up that had a flat front tire.
We aired it up and drive it home. I will not do that again!!!
It was a new tire also.:mad:
