900 Series Winch
steelsoldiers
3,958
Charleston, WV
Nice pic Dave :p
Here's one of the lines hanging loose. I don't have the truck in front of me to tell you what kind they are though. Let me know if you want the original pic that you can zoom in on.
As an aside, do you know where there any M939 winches for sale?
maddawg308
729
Front Royal, VA
Ha ha...I guess the first pic is how the hydraulic fittings look if you snap the picture while falling off the truck! ;)
Jones
Sacramento, California
I did a google search for "hydraulic fitting id" and got a site listing for jgbhose.com but for some reason when I posted the link here it wouldn't come up. Maybe you guys will have better luck. The site also has a tab marked "JGB Military" that looks like it's got some useful information.
The biggest difference on hydrualic flare fittings seems to be the seat angle; 37 degrees for JIC and 45 degrees for SAE.
73m819
314
gainesville, ga.
can a 900 series hyd. drive be fitted to a 809 series winch
rosco
27
Delta Junction, Alaska
If its a hydraulic fitting, it will be JIC. Use a try square on the male end - you'll be able to see that its not the 45 degree fitting.
SAE fittings that size are rare.
Lee in Alaska
steelsoldiers
3,958
Charleston, WV
DaveP said:
Chris i dont know of any more of these rite now. Ron i am about to find out if this will interchange. if by chance the hyd drive unit will work on the 809's, i may add a pump to the XM820. just for the heck of it here is the donor truck. and FYI nothing is availible from this unit at this time.
Sounds good Dave. Keep me posted if you decide not to use it or if you stumble across another one. Thanks!
