TCD
- 7
- 18
- Mound.House, NV
Howdy,
Over the weekend my 923-a2 quit running while going down the road. It would start after a 15-30 minute rest, run very rough and quit again in about 30 secs after pumping out huge clouds of black smoke.
So I got home ( a whole different story titled "Towing a 5 Ton with a Ford F-350... Uphill no less!") and started studying the TM's and Steel Soldier archives. I learned that some 923-a2 trucks had their large water separators removed and then the military changed their mind and the large water separator was to be reinstalled on the trucks. My truck did not get the large water separator/filter assembly reinstalled (I assume from reading that the original device is both a separator and a filter).
I did find this "floating" (not bolted down) on top of the frame:
Clearly my truck frame cross-member has never had the device installed.
My questions are:
1 - Do you know what the function of the floating valve is and do I simply remove it and put either a military or after market device in the fuel line (There seems to be to many lines connected to simply be "in-line")?
2 - Do you know of a TM that outlines reinstalling a new device from scratch (including the complete parts list)?
3 - My truck has only one very small fuel filter mounted to the engine block (I didn't take a picture of this filter) and during my preliminary looking around I did not see a bottom drain plug. Could the wrong filter be on my truck and therefore I currently have no separator function?
4 - Would it be a better idea to install a commercial water separator/filter and if so can you recommend one?
Once this sorted out I will then be able to start looking into my original problem within the fuel system.
As always all comments and thoughts are Greatly Appreciated!
Tom
PS: Yes I searched and searched and searched the TMs and threads and I read and read many TMs, threads and articles related to my questions. And no I don't need instructions on how to do a search. My questions came as a result of my research and I could not find the answers to the above questions. And FYI the way the P2P program link (http://www.steelsoldiers.com/5-ton-u...es-trucks.html) returns a 404 error and unless I missed a separate program it does not run on computers running Linux.
As always,
Thanks,
Tom
My questions are:
Tom
As always,
Thanks,
Tom
