93 m923a2
barkey16
Waynesville /nc
I have a 93 M923A2 with 8.3L. Start the truck as normal with the truck and washed inside and out. After cleaning as normal with the truck and washed inside and out. After cleaning the truck it would not start.only a clunk in the protective controller box. Purchase a new one hooked it up same problem . I needed the solenoids on the PCB , starter and batteries and everything was normal.
I even hooked slave cables to my Humvee and still the same.
i am at a loss. Any suggestions...
simp5782
Feo, Fuerte y Formal
8,285
Mason, TN
You need a test light. Check for power at the starter solenoid on the starter when someone hits the start lever. If you have power then the starter is bad. If no power. Then remove the starter switch from the dash and drop it down for wire/switch access. Will have 3 wires. 1 will be power to with the main switch on. One will be power out with switch in the run position. one will be hot with the start engaged.
Get that far and report back
