932 Huntsville Indy recovery
flibob
Nashville Indiana
Just picked up my 932 this morning many thanks to the GL crew and Wreckerman . Now the hitch. Going across post Redstone saw eng water temp was rising so stopped and added water to coolant reservoir, I continued up the road temp pegged but no other indication of problem. When I stopped at rest area 2 hrs up the road a small amount of steam came from the reservoir cap after stopping. I continued on to Nashville and my buddy's house. It is very hot outside 106F. Does anyone have suggestions?
NDT
5,870
Camp Wood/LC, TX
Not good. The high ambient temp does not cause the engine to run hot. Better verify the gauge is functioning properly and make repairs to it or the cooling system.
markmontana
Mesquite, NV/Layton, UT
You should isolate the problem before driving it. You could replace the thermostat to see if it is bad. I assume you have a long trip home? If so- you really need to stop and fix or get help and fix.
When I read this I cringed: "I continued up the road temp pegged but no other indication of problem. When I stopped at rest area 2 hrs up the road a small amount of steam came from the reservoir cap after stopping. I continued on to Nashville and my buddy's house."
No other indication of problem does not mean you are not causing excess wear on your motor.
These big trucks run a steady temp- even it it's over 100. As was pointed out- outside air temp is not the cause.
I hope you get if fixed- I have a feeling you will and wish you well. My post is just to point out the dangers (to your equipment) of driving an over heating motor.
flibob
Nashville Indiana
Bad news. Pulled the hose at thermostat and there is oil in the water. I am going to truck it on up to Indy.
Is there anybody in the Nashville area that has room to store the truck while I get a trucker? The truck is in Mt Juliet right now but I can drive a short distance. Thanks
hndrsonj
Senior Chief/Moderator
358
Cheyenne, WY
So I am assuming when you checked fluids upon arrival at Redstone there wasn't any oil in the coolant? It is NEVER a good idea to drive with a high temp indication without verifying that it is a bad gauge, even then I wouldn't do it unless I absolutely had to. A stop at an auto parts store and purchasing a cheap mechanical temp gauge would have probably prevented having a messed up engine.2cents
ranchhopper
136
south elgin illinois
I just fixed an 813 with the oil in the water your oil cooler is bad. Mine never went over 185 until I did the chicago memorial day parade ran a steady 200-210 found the oil in the water while trying to find a cause. I bought a new cooler the gaskets and retainer rings put it together and no more problems.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
I have the rings, but no oil cooler. There was a blue million of the coolers sold out of Creekside not too long ago, someones got them.
1,168
Memphis equipment most likely has the parts you need and a shop to fix it.
flibob
Nashville Indiana
Thanks all I have a place to store in Lebanon TN. I'll be on the phone in the morning getting the parts. Does anybody know which -20 covers oil cooler replacement? It looks like there are 4 -20's for the truck.
I have been busy with the maint but would say it drove very well.
The steering, ride, and noise were much better than I expected.
Even the heat in 109 degrees sure was better than bushoging with no umbrella.
