- 12,196
- 314
- 0
- gainesville, ga.
With the standard 939 ABS, each control valve controls one side of each axle, with the back axle being the sensor wheels. If you bob (neuter) a 939 and plumb one wheel to one valve and the other wheel to the other valve, if the abs activates, it could cause a spin, so how about plumbing both wheels to the front valve and plug the ports on the rear valve, or moving lines around so one valve controls one pot on each wheel and the other valve controls the other pots., this way the abs cannot cause a spin ???
Any thoughts on this ????
