939 retarder ???
73m819
314
gainesville, ga.
Does anybody know if the auto transmission contains a retarder but not hooked up, the reason I ask is that Cranetruck's 5t 8x8 had this in his trans. which he hooked up and it worked fine. A working retarder sure would help controlling down hill speed with out using the brakes. A jake brake has it's limits with a slip-a-matic. (if not in lockup, there will not be any effect)
73m819
314
gainesville, ga.
Thanks, I will get it moved.
Could a MOD please move this thread to 5t mods.
jatonka
57
Ephratah, New York
Retarders were used in the MT series of Allisons in the 60's and 70's, I had an International, 1972 diesel 10 wheeler with an MT41 and a 3 speed auxillary box. It worked fair. They create a lot of heat in the torque convertor. I own a 915A1 with 400 Cummins and Allison HT 750 and a Jake brake, and that combo will haul you down in ahurry. I pull a 22,000 pound lowbed with up the 28 tons on it and it really holds back on the hills. JT
cranetruck
74
Meadows of Dan, Virginia
Hey Ron,
Like JT says, the MT series (military TX200-6 in my case) has a built-in hydraulic retarder. The Army never had it linked up to a floor pedal, but the 1969 m656/xm757 vehicles have mounting holes for one. I have only verified that the retarder actuator on the transmission is present... never used it.
This transmission locks up in all gears and there is a fair amount of engine braking at all times, sufficient for an empty truck, IMHO.
