A little help on my M1009
Small Prepper
Gernantown, MD
Evening All
Need a little help with my 1985 M1009. ok that said
Heres what is happening.
1) Tried to start truck with hood up
2) Ground wire on front battery stated SMOKING and got really HOT
3) It sounds like HALF of the starter is turning??? or trying to start
4) The wire dose not look like the one that came with the truck. The wire is a # 10 gage. It is taped with electric tape.and is tight
5) Things I did on truck today
6) replaced fan blower motor
7) Cleaned misc. electrical termials (wiper motor, blower motor
Any idies?
Thanks For the help
ryan77
56
Cary IL
Sounds like your ground from the buss bar to the engine is bad, try clamping a jumper cable from the engine to the negative batt terminal! If that works u have a ground issue, I always run a extra ground cable from the negative terminal to a bolt on the engine by the alternator.
Terracoma
15
Albuquerque, NM
There should be a 10-gauge wire connecting the negative terminal of the front battery to the core support.
Assuming that your truck is still 24v, there should also be a 2-gauge battery cable running from the negative terminal of the front battery to the negative terminal board (bus bar) on the firewall. There should be a second 2-gauge cable connecting the negative terminal board to one of the intake manifold studs somewhere on the passenger side of the engine. Check to make sure that both cables are present, connected, and undamaged.
