A mans gotta do; what a mans gotta do
cjcottrill
32
Chillicothe, Ohio
I fired up the deuce to get a couple loads of gravel for the driveway. I was all loaded up and started to shift to reverse to back away from the loader and return to the scales when the shifter snapped off in my hand. Fortunately an old plumber always has his pipe with him - and trusty vise-grips. Looks odd but worked fine for the return trip. Take a look at the second picture, from the appearance of shiny metal only a small part has been connected - for who knows how long.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
now that's odd. That shift lever is a pretty beefy hunk of steel. I'm surprised it could snap off like that. It's hard to tell by the pic, but it looks like a pretty clean break too.
cjcottrill
32
Chillicothe, Ohio
The only part of the metal that was shiny -as in new break- was the narrow strip down the middle. The rest was well oxidized as if it has been like that for a long time.
mactiredearg
Denver, Colorado
Wouldnt surprise me if someone had trimmed it down to the narrow strip while it was still in service. My bet would be on a GI practical joke that hit the wrong target... :twisted:
m16ty
210
Dickson,TN
I saw that happen before. I was on a jobsite that had a a**hole superintendent. It didn't take much for him to throw a screaming fit. A dumptruck driver backed up to start to spread a load of gravel. When he went to take off to spread he tripped the gate, the truck lunged foward a little, and then stopped (the gravel piling up behind him). The Super started cussing him out and all the driver did was hand him the shifter out the window. That shut the Super up and all we did was roll on the ground laughing.
Digger09
New Jersey
With a lighter shifter you can load more gravel without going over the gvw. Nascar might steal that weight saving idea.:grd:
Dodge man
Fl
I got shifters, let me know.
I vote to keep the pipe! It looks SO redneck! :driver:
I used to keep a pair of vice grips on my off-road motorcycle. I clamped them on and wrapped the handles with safety wire to keep them from releasing (and a good place to keep the SW!) I crunched the shifter one time and broke the shaft and lever off and had to clamp the vice grips on the remains of the shaft and then had to reach down and hand shift it to get home but I got there.
Vice grips and baling wire, two things a true redneck should never be without!
yetti96
Fort Myers, FL
I had a 3 wheeler with vice-grips for a shifter for years. I had broken the pull start too many times to repair and then broke the shifter from jumping on it as I push started it every time I had to ride. It was a little dangerous, but worked like a charm. I could take the VG with me if I had to park it somewhere where it might get stolen (friends house, gas station, etc)
But to the OP, I say plumb it with warm water for the winter.
tie6044
42
Blaine, MN
I sold a truck a while back and that very same thing happened a day later to him. Same place and it looks the same as yours. I think the rod is welded to the bracket on the end that goes onto the tranny and it brakes at that spot.
cjcottrill
32
Chillicothe, Ohio
Welded back, so it's back on the road again. I might save the custom copper shifter for future use though. Thought about putting a rolling offset toward the driver side so I don't have to reach so far if it happens again.
