A2 axle/hub service
prholley
Euless, TX
Recently bought an A2 and have slowly been going through the PM items listed in the TMs. Question for you guys that drive your trucks a decent amount on weekends. I monitor hub temps, but really dread the day I have to tear into the hubs. Are any of you guys actually servicing the hub every 1k miles per TM, or just when hubs start getting hot or leaking?
Suprman
704
Stratford/Connecticut
You want to check the diff fluid levels it's easy to do there is a fill plug and fluid should be about 1/2 inch below that. The fronts have boots and grease pack if a boot is leaking or turn it needs to be replaced and possibly re packed. Other than that I haven't done anything else to my hubs.
