A3 Bed on A2, help hooking up auxiliary lights
Bowtie70SS
Goshen, Ohio
So, I have a M35A3 bed on my A2 and I need some help hooking up the rear auxiliary lights. I have the 3 light panel in the back as well as the 2 side lights. I do have the wiring harness for the panel. Is this as simple as matching numbers up? I always hated the big hole in the back of my bed and you can never have too many lights when you are on the road or playin. Thanks
1,142
The side markers are part of the taillight circuit (21 I think) so you need to tap into that circuit.
I have an A3 bed and plan on doing what you're doing, but I haven't bothered to look at the M35A3 wiring schematic to see where the sub harness for the markers integrates with the rear harness.
You should also have some brackets on each side of the bed int he rear for a side marker and reverse lights.
