AcDelco Replacement Lock Cylinders, General Anti-Theft Tips
firefox
General
1,844
51
Berkeley CA
One crazy idea I had would be to wire up a odorless smoke devise that fills up the cab and engine compartment once the truck moves more than 3 feet.
MarcusOReallyus
819
Virginia
So I've been wanting to get away from the common CUCV keys working for my truck. Changing out the cylinders is a pretty straightforward process, what I'm wondering is if the replacement AcDelco cylinders that you can get anywhere online are keyed unique or if they're all keyed the same model to model. I have no prior experience with them.
Dunno where you are on this, but I just replaced all three (doors and ignition) and they are keyed alike. I got them here. (Scroll down.) $44 and change, shipped.
Do yourself a favor and get a couple of the Exterior Door Lock Pawl Clips while you're at it.
Terracoma
15
Albuquerque, NM
^ I've got the same set of cylinders on my M1008 (from GMC Paul's), and they're far better quality than the generic set on my M1031 from Autozone.
Another vulnerable point of access on these old squarebody trucks are the wing/vent windows, where minimal to moderate tampering will overcome the old and worn out latches...
Tinstar
1,947
Edmond, Oklahoma
Okay, vehicle stolen + vehicle location solved = Vehicle recovered < happy endings to power of ten = theft problem solved, no?
Theft problem solved means it doesn’t get stolen in the first place.
LoJack shows where the vehicle is.
The condition that it will be in is anyone’s guess.
Recovery of a stolen vehicle is rarely a 100% happy ending.
Crashed, submerged, parts stripped, burned, vandalized (busted windows, spray painted, etc.), is the usual recovery condition.
Far from happy ending.
Merddin
-1
Cape Girardeau, MO
Ordered an ac Delco ignition lock cylinder off Amazon for 13$. Got two new door lock cylinders, ac Delco, from Amazon for under 20$. 89057683# on door cylinders. I threw box away already for ignition so no number.
Tinstar
1,947
Edmond, Oklahoma
I use the chain through the steering wheel all the time.
Sure it can be defeated easily, but it takes time.
Bolt cutters aren’t the most easily concealed item.
Usually, Crooks hate taking a lot of time to steal something.
Most thieves will not be initially prepared for cutting the chain/lock.
If it’s a target of opportunity, they won’t return in most cases.
Dedicated target and determined theft....? That’s a completely different issue.
If they want it bad enough, they’ll get it.
The trick is to make the target as unattractive as possible in the crooks eyes.
Hidden kill switches are excellent since they rarely will take the time to diagnose why it’s not starting and then look for the switch.
It takes less than 30 seconds to steal one of these.
Anything to slow that down and make them think twice and move on is a plus.
A thief with a tow truck.........?! LoJack will definitely help.
At least you’ll know where it is.
It’s never ending.
