Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Tthe wrecker has the pto bolted to the transfer case, should fit the same on the tractor. The pump the wrecker uses is driven by a short shaft and is mounted on a cross-member, dont know if that would fit on the tractor or not.
it kinda depends on how much volume you will need as to what type of pto unit you will need. for example if your gpm's are not that great you may be able to get away with a back pack unit on a standard transmission pto.
The m816 parts truck I have the tranfer case pto runs all the time no way to shift it in or out of gear the gear box that it go's to is what shifts in or out of gear I bought a transfer case pto from Memphis equipment $1400 rebuilt that does shift in or out of gear I plan to use it to mount a winch
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
