- 1,954
- 402
- 68
- Culver City, CA
Disclaimer: I have searched the following question extensively to no avail.
The drum on my 20K lbs. front winch spools out to quickly resulting in some bird nesting of the wire rope. Easy fix and after consulting the -20 TM, I firmly understand how to adjust the tension of the drag brake. Just put a drag link socket on it and do your 1/4 turn...right? No, it is not that simple of a task with an installed winch. There is approximately an 1 1/2" of clearance between the large set screw and the winch to frame main bracket to work in. I see no way to get a large screwdriver or a drag link socket with ratchet into that space to effect any kind of adjustment. I have thought of making my own tool out of some strap steel.
My question to all of you is have you made this adjustment with winch installed and what tool or contrived device did you use to make it. Thank you for any help in advance.
