bottleworks
- 3
- 18
- Central NC
I have finished making the brackets and whatnot for my A/C compressor. Compressor is now installed on the truck and ready for the next step... I am trying to figure out an evaporator housing. At first, I was planning on only having A/C with no heat. Being that it is starting to get cooler out (surprise!), I need heat too.
Here is my plan. Buy the Heater kit from Saturn and install the evaporator with the heater core/blower section. I would then add a cable controlled heater valve to stop coolant flow to the heater core for A/C operation. The A/C would just be controlled by a switch in dash to kick on the compressor. There would be no mix/blend door. It would be full A/C or full heat. One concern that I have is the loss of cold due to all the heat under the hood. I might be able to find some 1" thick insulation to coat the under hood box and ducting with.
Stupid idea? It will simplify the A/C side of the project. I shouldn't have to crimp new hoses. I can reuse the hoses from the donor car... The heater kit lists @ $265 on Saturn's web site.
