airmech3839
- 5
- 18
- Augusta, GA
Ok here goes.....My deuce is starting to act up...I keep having to bleed air out of the fuel system... first it started after I changed the fuel filters then went away after purging lines well..... then about every other day it would need a little bit drained right after start up... yesterday it needed it at startup cause I was out of ton for 2 weeks and didnt drive it any...but it drove fine all the way to work and home...then today she needed it again at startup this time it had alot of air....once it was cleared I drove it to work with no problems....then tonight I go to leave work and she starts up fine and idles fine ( I would normally get a little loppin in the idle that would tell me air was present) so i go to leave and as soon as I get it in second gear she nearly chokes out so I stop and get out and purg the air and this time I have a ton of air in there....5 min later its clear and I drive down the road....I dont get 5 miles before sje starts hesitating.....so I pull over and purge again....get going and so here I am riding along and about 15 miles later and not more than 2 miles from home she starts up again....so I limp home and park her...
I have no visible signs of aggressive leaking or heavy seepage...
I am running WMO and all filters are new less than 100miles and new air cleaner at same time... It is a daily driver so she usually runs alot...round trip is about 37-40 miles...the only time I get oil on the pavement is when purging air out...
I will have to see tomorrow in the daylight if I can see any other explination...
