TheAxeman
- 0
- 0
- Sag Harbor, NY
I took apart the air cleaner today to see how gunked up it was only to find out that there was not a drop of oil in the sump. As a matter of fact, it doesn't look like there has been oil in there in 20 years.....nothing but a little bit of rust. Before I go and put oil into it, I wanted to clean the actual filter. Is there a way of doing this? What weight oil should I put into it? Has any damage been done? Should the band clamp that holds it onto the carb be tight enough that the air cleaner can't spin?
While I have you, one other question.
Can someone tell me what the short pipe is directly behind the exhaust coming off the block on the passenger side near the firewall? It is about 1 1/4" in diameter, is metal, and points straight at the ground with the end of it cut at a 45 degree angle. When I took the truck out for its shakedown run, smoke was coming out of it. My service manual hasn't arrived yet so when it does I promise to stop asking elementary questions.
