Air guage hose fittings
70
Vermont
hey there, went and looked at a deuce that if all goes well I will be picking up this weekend. Air leaks are a common problem as ive read many times. This deuce has a cracked air line that goes from the junction to the air pressure guage that lets all the air out becauce it is almost in half. I am unable to disconnect the line and take it to napa and figure out what size and what threads i need on both ends. additionally it is in the middle of nowhere so runnin back and forth to an auto store not gonna work. i plugged the line with a golf tee amd hose clamp amd test drove her and everything is nice. but dont wamt to rely on that for the hour drive home. Can someone please lead me to the right fitting sizes? or lead me to the proper thread on the forum with this info? my mobile phone makes searching the TM's hard. Thanks for the help.
rustystud
2,389
Woodinville, Washington
If your just trying to get it home then plug the broken line. You don't need a pressure gauge to operate the truck. Once it is safe at home then you can go after all the problems.
Kaiser67M715
26
NH
I would grab some vacuum hose, either so the ID is the same size as the OD of the air line, or that the OD of the vacuum line is the same as the ID of the airline, and use some clamps to connect them- at the very least it will severely reduce the pressure loss
dmetalmiki
2,026
London England
This is exactly what I would do for the temporary fix. Cut it, Fit a tight (fit) good quality hose over both the ends, clamp them, and your good to go. As rusty said, do the proper fix when you have it home.
70
Vermont
awesome thanks for the tip on "splicing". ill give that a shot, if that doesnt hold to the pressure then i can clamp a threaded plug or something into it as rustystud suggested! Im excited about the truck but also a little worried that ill miss my m1008!
