Airpack rebuild (add pics-4/09)
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Finally got around to looking at the airpack. The pedal would stick going down, then let loose, causing some serious braking. Opened up the airpack, and the air side was half full of brake fluid. Guess I didn't need to lube the airpack after all! Looks like the pushrod seal was leaking.
Thanks to the great info here, and a kit off of ebay, rebuilding wasn't much trouble. Going to switch to DOT 3 while I am at it. Hopefully I put it back together right, didn't have any spare parts at least.
Well off to the store for a sprayer, going to build a pressure bleeder(thanks R4X4).
Dennis
1,827
RE: Airpack rebuild
Had the exact same problem with the airpack on the tractor. Rebuild took care of it right quick.
cranetruck
94
Meadows of Dan, Virginia
Re: Airpack rebuild
Stretch44875 said:
...... Hopefully I put it back together right, didn't have any spare parts at least.
Dennis
One important thing to remember is to install the U-cup seals with the "cup" facing the higher pressure.
DOT 3 has been good to me for a decade at least. :)
Ferroequinologist
Resident railroad expert
4,813
750
Liberty Hill, SC
RE: Re: Airpack rebuild
How does one 'convert' to DOT 3? I think I read something about it being bad for the seals and such? Or is it as simple as flush and fill?
vbrescueman
Dismal Swamp VA / Cochran,GA
I've rebuilt my airpack in the past...gonna do it again soon and post some pics. losing fluid in the system... airpack or master cyl? I believe a flush -n- fill w/ cleaner and air pressure will work. Will it get all fluid out of brake cyl or take lines loose at cyl and flush? TIA Ya'll
Doc :mrgreen:
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Well, I am using air to blow the lines clear. Takes a while to get most of it. Figure to pump some DOT 3 through it and call it good.
Sure cranetruck, now you tell me what way the seals go. :D No problem, the TM is pretty clear, and had my share of rebuilding cylinders and such.
Pics? to late now...
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Success! After running about a gallon through the braking system, I have brakes. I think the pedal is a bit lower now, hard to tell because the brakes push easier. Pushing hard on the brakes puts the pedal about 1/2 down, and will skid the rear tires.
Dennis
vbrescueman
Hey Stretch...did u disco the brake lines @ cyl or just push fluid out the bleeder ports? gonna do the same to my deuce but I've read that dot5 and dot3 make a mess if left together in the sys.
Doc
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
I can be hillbilly at times, I hooked an airline to the master cylinder and blew them out one bleeder port at a time, until no more fog. When I was filling the system with Dot 3, the fluid coming out was cloudy at first, then ran clear. Ran the truck around for a while and bleed a little more, clear brake fluid came out.
Dennis
gimpyrobb
dumpsterlandingfromorbit!
27,791
788
Cincy Ohio
So I took apart two airpacks to rebuild this weekend. Both had some wax build up in the air piston can. I am guessing this is not supposed to be there? What causes it?
tjcouch
Tampa, FL
I am replacing my airpack tomorrow . . . . I assume all of the fluid will drain out of my MC (and remote reservoir) during this process? (Unless I take some steps to prevent it . . . )
Floridianson
2,537
Interlachen Fl.
Just a thought but when I do my system fluid change I will use the sprayer first with just air or use compressed air and discharge all old fluid first then re hook up sprayer with BF then feed and bleed.
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Some pics from a recent rebuild. Was rebuilding one, and needed some parts so I grabbed the spare airpack. Check out the bore, a little rusty.
Dennis
gimpyrobb
27,791
788
Cincy Ohio
I would like to add, there is an article somewhere that details rebuilding one of these. Another member was kind enough to warn me, the end studs(as seen in the 2nd pic above) will break off if you are not carefull putting it back together. The article says to torque to 30lbs. Please be carefull when you are putting it back together, those studs are not on there that great.
