Allison transmission
57lafrance
lutz/fl
Can anyone advise if an Allison HT 740 will bolt to a continental R6602.
I am thinking about putting an automatic into my fire truck but i dont know if it would be compatible with a gas engine.
Thanks in advance
Suprman
701
Stratford/Connecticut
There are different bell housing bolt patterns. SAE number one is the Cummins 400 big cam and Detroit 70 and 90 series. The military ht740 trans has this pattern I believe it's the most common. You need to figure out what bolt pattern your engine has. The ht740 is for high torque diesel motors in the 1400 ft lb range. You might be better off with something a bit lighter duty.
57lafrance
lutz/fl
The more i research, i think its gonna be to much.
I have another question. I need the torque specs for the bolts that hold the vibration damper
BrushMaster Builder
Killeen, Texas
If this is a Deuce, I would re-power the truck with a 12 valve mechanical 5.9 BT Cummins and a AT540 Allison. They are both pretty cheap, easy mechanical engine and trans combo to install and work on and they would both fit nicely in a Deuce package without too much trouble.
quickfarms
25
Orange Junction, CA
The MT643 is a much better trans than the AT540 due to the torque converter lockup.
The truth is the op wants to put the Allison behind a gasser in an old fire truck.
The real problem you might have is the length of the trans is about 30". Depending on how your pump is set up that might be an issue.
