Alternator Issue
Pstyckiewicz
165
Massachusetts
I have been looking at diffrent things on my M1152A1 and noticed that the voltage meter stays in the yellow. In addition I unhook the battery the truck shuts off. It has the 200amp alternator. Is there anything I should check? Or bad connection?. And is this something that I could rebuild?
Thanks,
springer1981
1,184
Maine
Thanks,
I just replaced my regulator after troubleshooting the alternator. I posted about it as well as posted the Neihoff Alternator Troubleshooting PDF file. I highly recommend you test it based on the PDF, it will help you id the issue. https://steelsoldiers.com/threads/my-new-1992-m998-avenger.184818/post-2505017
Milcommoguy
2,402
Rosamond, CA
Thanks,
This is going to get crazy... What is the test to disconnect the battery when running?
Might be looking for a new start box if you keep that up.
Perpetual motion Humv ? CAMO
MarkM
CODE BROWN...It's all going to sh~t !
1,150
2,100
WOBURN. MA.
Never disconnect the battery/batteries while the engine is running. Fastest way I know to damage something (voltage spikes).
A multimeter will alow you to test the charging system without negative effects. The gauges are are always off to some degree.
Mark
