Alternator rebuild
chevywood
Manhattan, ks
Ok guys, first alternator rebuild and for the most part it has been pretty easy. The one problem that I have is where does the 3rd little plastic washer go. I have 2 under the metal finned piece that the diode connects 2 with the 3 nuts, but I am not for sure we're the 3rd would go
1,193
How about a picture of it?
1,193
I meant the washer.
chevywood
Manhattan, ks
The black ones are the ones that came out, image.jpgimage.jpgWhich they are a little thicker, the white one is the one left. Also, what is the 2 tab metal piece as there was not one that came out
1,193
The 2 tab thing is a resistor. It is not used in all alternators.
1,193
So, the white one is the only one you need to know where it goes?
1,193
Let me look at the -20TM. Off the top of my head, I dont recall for sure.
Could it be the "insulator" shown in that picture, at the top right?
1,193
Whoops, wrong TM, its in TM 9-2320-289-34.
Viewing with adobe reader, around page 264. Take a look at that.
Vhyle
Clarksville, TN
Off the top of my head, I believe that's an insulator for one of the posts that protrude externally from the case. But I'm not 100% sure.
Warthog
245
OKC, OK
So where did this third washer come from? Did you remove it from the alternator or was it in a kit?
The TM 9-2320-289-34 tech manual has a step-by-step explaination of how to rebuild the unit. It also shows where all the parts go. As far as the two tabbed resistor, all the Cucv units I have rebuilt used that resistor.
someone may have been inside the unit before you and not replaced everything back where it belongs.
i always like to take pictures of what I am taking apart so I can remember where everything goes.
chevywood
Manhattan, ks
As warthog said might of happened, I think somebody had been inside of it before me and possibly added a washer as well as not put in the resistor because when I went back and checked mine with the rebuild instructions I had it correct. I was even worried so I took it to oriely's to have it tested and it passed fine.
