Csm Davis
I have a 1010 and 1009 that I am thinking about setting up this way. Before anyone jumps my crap I have set up lots of 1009 cucvs to run the way they came from the factory, but the 1010 never worked right from the factory. I have read almost every thread on steel soldiers about 24 volt alternators and 12 volt cucv alternator setups. What I am looking at doing is putting a 12 volt alternator with a 24 volt alternator and doing different systems on the same truck, ie taking the upper alternator from the 1010 off and replacing it with a 12 volt alternator. this will leave me with a need for 1 more battery but I believe I could even do with just 2. I want keep the 24 volt starting an air conditioner set up and heater set up on the 1010, if this works for the 1010 why not the 1009?
I believe this is the way it should have been set up from the factory. If you have any constructive criticism please voice it here if it is not anything but arguing about why to keep it factory don't even post it will be ignored.
